I'm building my first PC and just wanted to double check that everything is compatible before I buy it. I'm 99% sure everything is fine, but I'd rather be safe than sorry.
Here's the parts:
PCPartPicker part list: https://pcpartpicker.com/list/JVJ7Hh
Price breakdown by merchant: https://pcpartpicker.com/list/JVJ7Hh/by_merchant/
CPU: Intel - Core i5-9600K 3.7 GHz 6-Core Processor  ($259.99 @ Newegg)
CPU Cooler: Noctua - NH-D9L 46.44 CFM CPU Cooler  ($52.06 @ Newegg)
Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard  ($161.98 @ Newegg)
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-2400 Memory  ($199.99 @ Newegg)
Storage: Silicon Power - S55 480 GB 2.5" Solid State Drive  ($60.98 @ Newegg)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Newegg)
Video Card: Gigabyte - GeForce RTX 2070 8 GB WINDFORCE Video Card  ($499.99 @ Newegg)
Case: Corsair - Air 540 ATX Mid Tower Case  ($99.99 @ Newegg)
Power Supply: Corsair - HX Platinum 750 W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($129.99 @ Newegg)
Total: $1524.96
Generated by PCPartPicker 2018-12-02 19:49 EST-0500
Thanks for the help!
https://linustechtips.com/topic/1003154-first-pc-build-machine-learning/
The Prime Z370-A will need a BIOS update to work with the 9600K.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
4 minutes ago, dpopp783 said:
Is that easy to do or is there a different model you would recommend?
I'd suggest getting z-390 just for the safety that the bios will work
If you're formally an engineer, avoid responsibility. That's what senior engineers get paid for.
2 minutes ago, dpopp783 said:
That's also a Z370 motherboard, you need a Z390 one like the Gigabyte Aorus Master.
Just now, dpopp783 said:
Please quote people when you react, otherwise i might not have seen your reaction. I'd go with z390, not z370. What is your budget for the board and what formfactor?
This or the aorus pro (/pro wifi)
14 hours ago, dpopp783 said:
Gigabyte - Z390 AORUS PRO WIFI ATX LGA1151 Motherboard
Is this the one you're talking about?
Yup
