Every 10 minutes or so, wsappx goes from using almost no CPU power to using 90% CPU for 1-2 minutes.This happens both in and out of games. The PC is one day old btw. I can't see a pattern to it, except for the timing, or what triggers it. Does anybody know how to stop it from spiking?
System details are on my profile
https://linustechtips.com/topic/1003000-wsappx-using-90-cpu/
What did you find when googling the problem and what have you already tried that didnt work?
And what are your specs.
That i have to ask these questions only means it will take more time for you to get help. ;)
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1003000-wsappx-using-90-cpu/#findComment-12032445
This deals with windows "universal" apps that are downloaded from the windows store. So every time it spikes it either is installing/updating/checking for updates/launching/closing an app.
https://linustechtips.com/topic/1003000-wsappx-using-90-cpu/#findComment-12032449
  • CPU
    AMD Ryzen 7 2700x
  • Motherboard
    Asus ROG Strix B450-F
  • RAM
    4x8 GB Corsair Vengeance RGB 3200 Mhz
  • GPU
    MSI RTX 2070 Armor
  • Case
    Thermaltake Core P3
  • Storage
    Samsung 970 Evo M.2 500 GB
  • PSU
    Corsair RM750X
  • Operating System
    Windows 10 Pro N 64 bit
    I've tried disabling the Windows Store in Local Group Policy. @HanZie82
https://linustechtips.com/topic/1003000-wsappx-using-90-cpu/#findComment-12032461
