I don't know what fittings your going to use but most series and brands have these.
I would say get some of these, i have them and use them for the tight turns.
https://www.ekwb.com/shop/ek-af-angled-2-45-g1-4-black
You can always attempt a few goes with bending, there will always be something painful to connect its good to have a backup solution with you.
But with that distance you will likely need 4 of them or at least two of them with some extension pieces.
CPU | AMD Ryzen 7 7700X | GPU | ASUS TUF RTX3080 | PSU | Corsair RM850i | RAM 2x16GB X5 6000Mhz CL32 MOTHERBOARD | Asus TUF Gaming X670E-PLUS WIFI |
STORAGE
| 2x Samsung Evo 970 256GB NVME  | COOLING
| Hard Line Custom Loop O11XL Dynamic + EK Distro + EK Velocity  | MONITOR | Samsung G9 Neo
https://linustechtips.com/topic/1002605-help-custom-loop-ideas/#findComment-12030363
