I just got my SLI setup.
I did some benchmarking, and these are my results.
On BF4 I get this:
Without SLI:
Min, Max, Avg
89, 126, 113.357
With SLI:
Min, Max, Avg
86, 232, 132.382
And on BF3 I get this:
Without SLI:
Min, Max, Avg
77, 108, 92.058
With SLI:
Min, Max, Avg
141, 218, 171.045
How is it possible that on BF3 SLI works fine and gives me huge improvements,
but on BF4, it's not really that special? I know my max fps is way higher, but on avg it doesn't really matter...
Anyone know how I can make it run better on SLI?
I heard some people said I need to OC my CPU,
but I only got an Cooler Master 212 Evo, and now my CPU is at 3.9GHz 30C at idle, and 65/67C under load (prime95) (at 1.165v).
So I don't know if I can be safe OC'ing it to around 4.2/4.3... (I don't know that much about OC'ing)
I hope anyone can help me out with this!
https://linustechtips.com/topic/100124-770-sli-help/
Use GPU-Z to monitor your GPU loads during gameplay in SLI on BF4 and share your results. We'll probably need some more info. Have you updated your drivers to the latest version as well?
Corsair 900D | MSI MPower Max Z87 AC | i7-4790K @ 4.7Ghz | 1080 Ti SLI | 16GB Corsair Vengeance Pro 2400
XSPC Raystorm | EK-FC Nickel GPU block/backplate | 2x Alphacool UT60 480mm & XT45 240mm | 11x Linus Edition NF-F12
Schiit Modi/Magni 2 Uber | 5" KRK Rokit G3 | KRK 10S2 | Acer Predator X34 | Dell S2716DG
https://linustechtips.com/topic/100124-770-sli-help/#findComment-1339249
I've updated them, alltough I heard that some people said the performance are worse with the new driver...
I'll try the GPU-Z tomorrow, as I need to go in a bit.
https://linustechtips.com/topic/100124-770-sli-help/#findComment-1339258
It's called scaling. It varies so expect that.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/100124-770-sli-help/#findComment-1339262
BF4 isnt optimized for SLI yet.
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/100124-770-sli-help/#findComment-1339264
This also
https://linustechtips.com/topic/100124-770-sli-help/#findComment-1339266
SLI works with the game but it needs to be optimized properly, your minimum FPS is still above 80 so I don't see the issue
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/100124-770-sli-help/#findComment-1339278
On BF4 I get this:
Without SLI:
Min, Max, Avg
89, 126, 113.357
With SLI:
Min, Max, Avg
86, 232, 132.382
Without SLI:
Min, Max, Avg
77, 108, 92.058
With SLI:
Min, Max, Avg
141, 218, 171.045
BF4 has been know to be really heavy CPU bound compared to previous titles
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/100124-770-sli-help/#findComment-1339293
That was true of the first driver that Nvidia released for the game... there have been about 4 new drivers since then. I suggest upgrading to 322.21.
https://linustechtips.com/topic/100124-770-sli-help/#findComment-1344120
