Read your motherboard's recommended RAM slot configuration, it's usually the outer most slot and then the second closest to the CPU socket, instead of the inner 2 slots. Also, Ryzen doesn't have integrated graphics, so you have to have a confirmed working GPU. I see you have one, but do you know if it works?
Follow the instructions outlined in this post
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/1001153-ryzen-2600-first-post/#findComment-12016167
GPU works,  tried it past night. Ram A1 and A2
https://linustechtips.com/topic/1001153-ryzen-2600-first-post/#findComment-12016186
It looks like the recommended configuration is slots B2 and A2. Try all the steps listed in the README thread, then if you're still having issues report back.
https://linustechtips.com/topic/1001153-ryzen-2600-first-post/#findComment-12016192
The pc is fine and running now. It's just showing half of the available ram as usable I'm windows 10. It's the HDD and windows I used on my old rig. Removed paging and changed the boot setting but nothing changed.
https://linustechtips.com/topic/1001153-ryzen-2600-first-post/#findComment-12020170
Is the RAM in the correct slots like I mentioned? You’re sure there’s no dust or debris in the slots? You’re sure they’re in all the way? You’re sure there are no vents pins in the CPU socket?
https://linustechtips.com/topic/1001153-ryzen-2600-first-post/#findComment-12020181
take the cmos battery out for a couple minutes for shits and giggles. if you're certain everything is plugged in correctly i'd have to point to faulty hardware, cables themselves or the motherboard settings, hence removing the cmos battery for a few. could be the board itself but lets hope not.
also do u have any spare ram lying around that will work in that board to test if the ram is the issue? would be a good idea
https://linustechtips.com/topic/1001153-ryzen-2600-first-post/#findComment-12020375
