(HELP) Audio Setup Recommendations
Hi all,
I'm new to Audio but I'm trying to put together a high quality build. I have decided on pairing some Yamaha HS7's with the Yamaha HS8S subwoofer. For headphones, I have decided on the Beyerdynamic DT1990 with a Modmic.
My question for you is: What additional sound devices do I need to maximize this setup? I am primarily talking about amps, pre-amps, DACs, headphone amps. Whatever the hell else, I don't really know them all. In addition to that, maybe some stands and/or isolation pads that will help these devices. One thing I am interested in is being able to keep both my headphones and speakers plugged in at the same time and be able to switch between them from desktop.
https://linustechtips.com/topic/1001065-help-audio-setup-recommendations/
I got the Schiit Stack and called it a day. Magni 3/Modi 3. Power my Sennheiser HD 6XX headphones just fine. They say it can be used for pretty much anything. I'd believe it, but I don't have $1500-2200 to spend on some HD 800 S or HD 820's.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
