So I had a Phanteks Enthoo Evolv ITX case which was notoriously bad for airflow with the inno3d gtx 970 in it. Temps were near max but nothing was thermal throttling if I took the front panel off. However, the nosie from the fans were extremely loud and distracting when I gamed. So, I ordered the NZXT Kraken G12 along with the Corsair H55 and Noctua A9x14 to cool it the 970. I know it was my fault that I didn't check thorougly if the G12 supported non-reference cards, but I still managed to ghetto mount the AIO. Temps on the GPU chip was fine but since this was not an EVGA icx card, I could not monitor the VRM/ Vram temps. Low demanding games would run fine but whenever I ran a more demanding game such as Divinity Original Sin 2, the gpu would shut down and I had to hard restart the computer. I later found out that if the power limit went above 50%, it would do that, so I again ghetto mounted the noctua fan onto the G12 bracket.
I thought everything would be fine and dandy since I installed the mid plate back on the card with new thermal pads along with active airflow with the noctua fan, but while gaming, the computer shut off by itself again and would not reboot. I also smelled smoke coming from the GPU so I assumed the card was burnt. I attached some pictures showing the bare PCB of the card and I suspect that the R75/ R76 thingys are burnt since they show burnt marks on the thermal pad.
Does anyone know what those chips are and if they're fixable? I'm currently leaning more towards getting a new card and if I do, any recommendations?
https://linustechtips.com/topic/1000959-burnt-gtx-970-help-needed/
Sorry, my dude, but I think you're pretty far past fixable. GPUs are super complicated, by nature, so unless you have very good soldering skills, in the words of Sans, "You're gonna have a bad time."
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
What? If the airflow in the case was the issue why didn't you spend the money you spend on those coolers on a better case?
|| Processor: AMD Ryzen 5 2600 || RAM: 32GB (4x8GB) Corsair DDR4 Vengance (3000) || Motherboard: ASUS Prime B450-Plus || Graphics Card: Gigabyte RTX2070 || Storage: 750GB SSD (2 Drives), 3TB HDD (2 Drives) || Case: NZXT H500 || Power Supply: be quiet! Pure Power 11 600W ||
It popped, should of just redone thermal paste before improperly mounting a g10 on it. Also your case airflow is probably is a part to play in your temps being so high in the first place.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
Yeah, I figured as much. I was actually thinking of shipping it to the Rossman Repair Group guy whom I quite enjoy watching to see if he could do anything about it. Would seem like a cool video.
I thought about it, specifically switching it with the loque ghost s1 or dan case a4 since I was going for an ultra compact PC in the beginning. But I valued silence more and wanted to tackle the GPU fan noise problem first and fix the airflow along the way. Hence why I thought an AIO would be the perfect solution, but I didn't factor in my card into consideration.
When I mentioned the thermal pads, I meant that I applied new ones to the VRMs and VRAMs, not the chip itself. I wouldn't be that dumb to put thermal pad on gpu core itself. And yeah, should've definitely researched more about the case before making a purchase last year.
