I want to watercool my 2080ti and i5-8600k, looked at some videos about the installation of the block on the founders edition and found the type of block they used.
Block: https://amzn.to/2Bylmyo
Backplate: https://amzn.to/2zrNu58
I was wondering what type of radiators i should get and if anyone could recommend me any kits for me to buy. or any other type of help would also be appreciated
https://linustechtips.com/topic/1000825-watercooling-help/
What type of budget are you working with for this. 500-800 is easy to spend on a full custom loop. Other things of importance... do you want it mostly silent or are you okay with some noise? What case are you using?What motherboard?
https://linustechtips.com/topic/1000825-watercooling-help/#findComment-12013296
https://pcpartpicker.com/list/RMKbZR
my current build. i imagine ill have to change the case to a larger one which is fine, i have the i5-8600k clocked to 4.7
as for my budget im hoping to hover around 500-1000, noise doesn't bother me but the quieter the better. I just want lower temps than the 84C im getting OC my gpu.
https://linustechtips.com/topic/1000825-watercooling-help/#findComment-12013353
Well that will def happen. It should be in the mid 40's or so after.
https://linustechtips.com/topic/1000825-watercooling-help/#findComment-12013368
So assuming you go with a bigger case like the View 71... then this would be what the loop would look like.
https://www.ekwb.com/custom-loop-configurator/shared/oW5bfd9722af7f7
You already have the gpu block so shave off $155 there. You also can shave off another 50-60 if you don't go with the RGB pump/res combo and just get a plain version. I would also probably drop their tubing and the coolant they supply and just go with Primochill tubing and use their liquid utopia for my loop. That will cost you 20-25 instead of the 35ish here. You can get cheaper fans, but the ones here will give you plenty of airflow while also being silent.
https://linustechtips.com/topic/1000825-watercooling-help/#findComment-12013547
thanks man appreciate all the advice, its been a huge help
https://linustechtips.com/topic/1000825-watercooling-help/#findComment-12016671
