10 pin usb headers
Go to solution Solved by Mira Yurizaki,
10 minutes ago, cadenm1223 said:
Its a K7SEM motherboard made by ECS.
According to the manual, it should only have nine pins. But considering an eBay posting has the motherboard with 10 pins, I'm going to claim this is a hallmark of ECS quality.
In any case, see if the top-left pin (from the picture's point of view) has a PCB trace at all going to or from it. If it doesn't, snap it off. Now you have a 9-pin USB header. One of the pins in a USB header literally is for keying the header, so you shouldn't lose functionality.
10-pin USB header? Doesn't sound right. What year PC are we talking about? Because USB 2.0 header has always been a 9-pin connector on the board and IIRC USB 1.1 used same connector, if they even had headers for USB 1.1.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/1000398-10-pin-usb-headers/#findComment-12009576
Are you sure it is USB?
https://linustechtips.com/topic/1000398-10-pin-usb-headers/#findComment-12009591
https://linustechtips.com/topic/1000398-10-pin-usb-headers/#findComment-12009699
5 minutes ago, ZcanKal said:
It may be a proprietary connector, judging by the color of the PCB, it's an old board.  Manufacturers really liked using proprietary internal connectors in those days.
If you go to page 28 it will explane the header but it does not tell you anything about how to connect it.
mans.io-raGOc1f8.pdf
https://linustechtips.com/topic/1000398-10-pin-usb-headers/#findComment-12009704
04185F4599E2FE0F0D7F0A9A671B6F2ABCF89F8D
nice idea
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/1000398-10-pin-usb-headers/#findComment-12009720
