Windows 10 October update happened and now there is no detectable audio. I also replaced a motherboard in my computer. I've tried to install drivers but they all error out via time or just say something went wrong. I've tried to reinstall Realtek but no luck, just errors out. Tried to go into "device manager" to update things, but no luck. I downloaded the driver files and tried to select them for "Other Devices"(under other devices i have a Audio Device on HD audio bus) in device manager to update it but yet again, no luck.
photos attached are the audio outputs i think, only ones i can trouble shoot are through steam, and there is a photo of the 3 updates that timed out
Now what
https://linustechtips.com/topic/1000332-no-audio-found/
Just now, Froggo56 said:
gigabyte B85M-D3H rev. 2.1
Its on the f15 bois update
I believe there was an issue with new Windows update and Intel hardware that caused audio to stop working.
But anyways, they show up as audio devices, have you tried selecting the correct one from the volume menu?(The arrow above the slider with the speaker/audio device name)
https://linustechtips.com/topic/1000332-no-audio-found/#findComment-12009152
huh? scrennshot plz
if you mean the sound video and game controllers for the audio inputs, they are there but they wont output sound nor do they show up for trouble shooting
https://linustechtips.com/topic/1000332-no-audio-found/#findComment-12009170
1 minute ago, Froggo56 said:
huh? scrennshot plz
fix-Sound-Volume-Too-Low-in-Windows-10-8
You see the "Speakers(Realtek ..... Audio)  ^" in the image? Click that(on your own pc), and try every option there is in that list.
https://linustechtips.com/topic/1000332-no-audio-found/#findComment-12009183
There is no slider, when i click on it a trouble shoot pops up for "steam Streaming" but under the device manager i have 5 outputs that dont show up. I think the first 2 Audio Devices are what my headset should show up as (A40's plugged in by the lime green and pink plugs from the back of the motherboard)
https://linustechtips.com/topic/1000332-no-audio-found/#findComment-12009226
That's really weird. Can you test if it works with headphones?(Front and/or back of PC)
https://linustechtips.com/topic/1000332-no-audio-found/#findComment-12009240
ive tried the front and back ports for headphones yes, both show have no sound and wont let me trouble shoot why. Drivers are as updated as they can get. it just wont give me sound. Ive done restarts, ive made sure the motherboard ports are enabled but nothing
https://linustechtips.com/topic/1000332-no-audio-found/#findComment-12009252
Then I really have no idea, sorry.
https://linustechtips.com/topic/1000332-no-audio-found/#findComment-12009260
1 minute ago, wONKEyeYEs said:
If I were to change my MB and leave the original OS on  the drive I would be surprised if I didn't have probs.
Fresh OS install.
Go to MB manufacturer for drivers.
Why would there be problems? It would just reconfigure the system for the hardware, I've done it multiple times.
https://linustechtips.com/topic/1000332-no-audio-found/#findComment-12009307
Fresh OS install.
Don't have a disk and ive tried to use the in setting version to clean up windows but it just gets stuck... Microsoft have a downloader on the website?
https://linustechtips.com/topic/1000332-no-audio-found/#findComment-12009309
