I currently have a 1060 6gb and an ryzen 5 1600x in my system i got a vega 56 on sale during black Friday and wanted to know how much power i will need. i have a 550w psu right now and im sure that will work fine for the vega but its non modular and im sick of all the cables stuffed in the back so i want to get a new modular psu anyways so i figured just for the hell of it i want to have enough power to supply both the vega and the 1060. i know the drivers will hate each other and i know the 1060 will practically be useless but i want to do it just to say i can. also if anyone knows any programs that let nvidia and amd drivers work better together let me know. thx.
https://linustechtips.com/topic/1000087-how-much-power-do-i-need/
Ok so... What is your question?
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
vega56 = up to 255 watts
gtx 1060 up to 125 watts
if you're gonna play games, only one will run, the other will most likely idle consuming 5-15 watts.
cpu up to around 120 watts
motherboard, ram etc around 15-25 watts
hdd ... around 6w, fans  2w each etc
note that you need to have one monitor connected to the card, if you want to use the card for games, otherwise card without monitor can basically be used only for cuda, opencl, video decoding and encoding etc
To run both cards at the same time and to account for overclocking the cards and the cpu "just in case" around 580w. I'd check the psu tier list and find something decent quality. I'd say 650 would be the recommended, maybe a 700 or 750 would be worth considering if you want the extra headroom for something later or just to keep it a bit cooler n quieter.
On 11/26/2018 at 1:26 AM, LukeSavenije said:
Which psu do you have? If it's a decent one, you're fine with 550, but if not, upgrading wouldn't be a bad idea
its a corsair works great no problems so far except i think it only has 2 pcie connectors and the vega needs 2 just to run.
https://www.newegg.com/Product/Product.aspx?Item=N82E16817139202
yeah i got 2 monitors probably just going to hook up my secondary monitor to the 1060
If you want to use the 1060 and Vega 56, I would say 750W minimum, unless you seriously undervolt the Vega card. Overvolting might require an 850W. If you just want to use the 56, which like you mentioned you probably won't even be able to use the two different cards because of driver issues, then you might be bale to squeeze by on your current PSU. I would still aim for undervolting though.
im undervolting slightly anyways because it has a reference cooler and gets hot as hell. i think i have my highest at 1120 mV. also im not afraid to take it apart because i like my parts as cool as possible but im having a hard time finding an aftermarket cooler for the vega, i wouldn't think it would be hard since its a reference pcb. Know any decent coolers that wont cost me an arm and a leg.
I would have said waterblock it, until those last couple words. I'm not much for aftermarket GPU air cooling so I'm not the right person to ask, sorry. Honestly I'd just roll with it, GPUs are meant to be hot anyways.
yeah i really want to waterblock it but i dont have like $500 to spend on a full loop and the block and stuff. its just odd for me because with the 1060 i was able to keep it under like 48c with heavy load but now i open a game and the vega jumps to 60+ i know thats not that bad but i like my stuff as cold as possible, to keep it working for a long time.
You must have way over spent on a cooler for that thing lol I've never heard of that cool a card before.
edit: You can always go with an EK Fluid Gaming kit. Full loop for $240, then throw on an extra 240 or 360 for like $70. https://www.ekfluidgaming.com/ek-fluid-gaming-a240r
well no i never messed with the 1060 i just dont care about noise so i bought some mining grade fans and replaced all my case fans so my pc has mad airflow my ryzen 5 1600x has never hit 40c on air cooling nop matter what i throw at it.
Interesting. I guess my headphones don't lend well to a bunch of fans so I can't really do that.
1 hour ago, Jharring3050 said:
how many watts do you recommend?
Wrong
You need a good quality PSU first, wattage is second.
ie a be quiet Straight Power 11 (450/550 or 750W).
"Hell is full of good meanings, but Heaven is full of good works"
