Need help extending dads wifi
Cole5
My dad has a wireless router in his house, and now he wants wifi in his garage, which is basically a steel box, he gets some signal on the end nearest to his router and wants his whole garage to have wifi for his phone and smart TV,
Best way is to run an Ethernet cable into the garage or as close as you can and connect an access point to it to provide a WiFi signal.
You'll likely come across WiFi extenders, but I wouldn't recommend them, they tend to be crap.
You can buy an old laptop and use it as a wifi extender from a junkyard for $20
Please don't argue with me, I am just trying to help, or be helped. (we are all humans right?)
to build on this... powerline adapter to an Access point.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
I would not do this
take the effort and run a cat6 to the garage, probably run 2 while you are at it.
install an AP
