Asus Zenbook UX430UQ fan noise: issue?
Solved by GoofyBiscuit,
10 minutes ago, themctipers said:i have a UX430UA, and can confirm that the fan is really loud in idle.
5 minutes ago, OmJo93 said:I had two of them, and had the same issue with both. That's just how they run.
Download a program called Notebook FanControl and set the profile to the Zenbook 360 (or something like that) and the fan should behave normally.
Also, if you haven't yet, update the BIOS to the latest version. It helped quiet the fan (though it still turned on) in my case.
Alright, thanks for the help!
