Gigabyte System Information Viewer and Fan controller
Solved by clementk,
I have nothing that is 21c
I had this issue with my gigabyte board. and a gigabyte rep told me that the program wont run your profile until you start it up once in the desktop. so i sent the board back and grabbed this Asus.
Okay just wanted to make a Finishing post to this on how i Got around to make a "Kinda Fix"
1) go to where the .exe is located.
2) Open your startup Folder with Win+R and the "Shell:startup"
3) make a txt file with the Path in from the .Exe and save it at <AnyName>.bat
and your done. it will now run on startup every time.
