Gigabyte 1660 OC Fan noise issue
1 hour ago, TheNamesLigma said:I am using the performance setting. And i have 5 fans including cpu fans in may case.
Also, How can i set a custom fan curve, the gigbyte aorus software also doesnt open for some reason.
You'll need MSi Afterburner. (Don't worry it works on all graphics cards) Download it from Guru3D and install it.
Once installed and running, you'll need to do the following:
Open the settings menu underneath the fan speed section
Then choose your startup options
press the fan tab up the top
Enable User defined fan control and ensure the curve is at default. (you can play with this once you get to use afterburner more
Click OK at the bottom and ensure afterburner now looks like this
Once it does click Minimise to finish NOT close
