Water cooling my arc midi r2
Artem
Hey guys,
I don't really have to time to do a full build log, but a few members asked me to do a build log, so here's my best attempt. Keep in mind I just snapped a few iphone pictures here and there since I don't have a decent camera. My brother did take a few pictures of my build previously with his camera, so the before pictures are decent.
Before:
Planning and parts list(ignore the extra cpu block in the cart):
Let the modding begin:
If only the arc was a little taller, id be able to get two of these rads in here:(
Pump assembly
Cleaning the rad with some vinegar and water
The copper that the vinegar removed from the rad liked the nickel plating on the aqua pipe
If anyone tried fitting a 360 in the midi r2, they know it't quite a task, since the other holes are counter-sunk and the ones I drilled weren't, I had to sink them myself with a screw and a block of wood:)
Test fitting
Swiftech splitter in, awesome tool
Leak testing
All done, time to wait for the bubbles to come out.
Thanks for looking! :D
CPU: Intel i7-3770k at 4.8Ghz  CPU Cooling: 320mm UT60  Motherboard: MSI Z77A-GD55  RAM: G.Skill Ripjaws X Series 16GB 2133Mhz (2x8GB)  SSD: Intel 330 Series 120GB  HDD: WD 1TB Caviar Green  GPU: EVGA GTX 780 x2  Sound Card: Creative Recon3D  PSU: Raidmax RX-1000AE 1000W  Case: Arc Midi R2  Monitor: Benq XL2420T at 129Hz  OS: W8 64Bit  Keyboard: Razer Blackwidow 2013 Ultimate  Mouse: Logitech MX518  Mousepad: Steelseries QCK+  Headset: Turtlebeach X12 (Temp.)
Wow!! Very nice with the 360mm radiator mod :)
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
Wow!! Very nice.
Thanks!
That is a lot of rad space for a cpu. Are you going to add the gpu's in?
Yes sir, couldn't afford to buy everything at once, would of cost me like $1200. I'm gonna wait for the next gen flagship cards from invidia, then get water blocks for them and add a 240 ut60 up front to help.
how did you mount the 3.5 hdd?
2500k 4.0ghz,GTX 1070 oc,MSI Z77A-GD55,G.SKILL Ripjaws(4 x 2GB)DDR3 1333,OCZ Arc 100 240gb,Samsung Spinpoint F3 1TB,Corsair TX 750w v1,CoolerMaster HAF 912,Hyper 212 EVO
Nice work but.
To cool the cpu just cost you nearly $700.
Was it worth it? Are the temperatures that much lower? How much extra performance has that $700 got you.
Nothing to see here - move along.
Nice work but.
It was nearly $700 to buy all the essentials to start a nice loop. adding another 240 rad in the front and two gpu blocks is going to cost me just $350 more. So the full loop should cost me around $1000. It was worth it for me because now my system is completely silent with better temps. It's not always about performance, some people want a quiet system. I mostly did it for fun as it interested me.
Ah okay.
*Moment when I actually prefer how it looked before with the NH-D14.
lol whatever floats your boat.
