Help choosing a monitor
Solved by michaelk12,
Response time doesn't really matter. First of all, it is physically impossible for a human to tell a few thousandths of a second difference, 5 vs 8 for example, no matter what anyone tells you. Second, there is no industry standard for measuring response time. The number they give you may or not take into account certain variables that impact the total latency. I'd recommend what @ELSknutson said, displayport-> hdmi adapters are quite simple and cheap. That's one of the big benefits of DP, that it is the easiest to adapt from to another plug. http://www.amazon.com/gp/product/B004C9P9TM?gclid=CjwKEAjw2cOsBRD3xNbRp5eQxzYSJADZGYbzWGiNXqysLwgOShv_XszbdISCcyZJoWSnPBqR10TxgxoCeoPw_wcB
