Cable shipment and cheapo wall mount review - I <3 Monoprice
Syntaxvgm
Monoprice is love, Monoprice is life
Would totally recommend them
Cables are peripherals, right?
My crap camera on my moto x is kinda far off, the hdmi cables match the red on my desk (which is like a pure ff0000 red) and the Ethernet cables are actually orange for some reason. Might contact them about that or at least get a color sample from them before I order 1000ft spools of cable in the future.
Here's a list of what I got -
3 6ft PSU cables
5 6ft mini-b usb cables
3 6ft DP to Single link DVI cables (remember kids, you need an active adapter for displayport to dual link DVI for a dvi device with resolutions above 1920x1200)
3 10ft red HDMI cables
1 mini-DP to HDMI (this will work like single link dvi)
4 7ft red (orange I guess) Cat6 cables
1 Full-motion cheapo vesa wall mount
I don't think all of the options were the smallest guage of wire, or the cheapest cables avaible, but my total was still only 79.93 USD with 12.10 USD shipping. Not bad.
I'll be updating this thread when I get my screen within a week or so and see how that 16$ wall mount hold up.
The mount holds up to 24" screens, and I'm putting a 27" one on it...cause I'm a badass or something...it's well under the weight rating so I should be fine. If not I got a mount on my 24" tv that is way too heavy duty for it, and I could just use that instead if needed. But the monoprice mount has rotation so hopefully it works out. The reason I got such a cheap mount was I hear the korean monitor I'm getting has a vesa mount, but the mounting holes have some flex, so I won't be moving it around much once it's mounted.
Will update!
muh specs
Gaming and HTPC (reparations)- ASUS 1080, MSI X99A SLI Plus, 5820k- 4.5GHz @ 1.25v, asetek based 360mm AIO, RM 1000x, 16GB memory, 750D with front USB 2.0 replaced with 3.0  ports, 2 250GB 850 EVOs in Raid 0 (why not, only has games on it), some hard drives
Screens- Acer preditor XB241H (1080p, 144Hz Gsync), LG 1080p ultrawide, (all mounted) directly wired to TV in other room
Stuff- k70 with reds, steel series rival, g13, full desk covering mouse mat
All parts black
Workstation(desk)- 3770k, 970 reference, 16GB of some crucial memory, a motherboard of some kind I don't remember, Micomsoft SC-512N1-L/DVI, CM Storm Trooper (It's got a handle, can you handle that?), 240mm Asetek based AIO, Crucial M550 256GB (upgrade soon), some hard drives, disc drives, and hot swap bays
Screens- 3  ASUS VN248H-P IPS 1080p screens mounted on a stand, some old tv on the wall above it.
Stuff- Epicgear defiant (solderless swappable switches), g600, moutned mic and other stuff.
Laptop docking area- 2 1440p korean monitors mounted, one AHVA matte, one samsung PLS gloss (very annoying, yes). Trashy Razer blackwidow chroma...I mean like the J key doesn't click anymore. I got a model M i use on it to, but its time for a new keyboard. Some edgy Utechsmart mouse similar to g600. Hooked to laptop dock for both of my dell precision laptops. (not only docking area)
Shelf- i7-2600 non-k (has vt-d), 380t, some ASUS sandy itx board, intel quad nic. Currently hosts shared files, setting up as pfsense box in VM. Also acts as spare gaming PC with a 580 or whatever someone brings. Hooked into laptop dock area via usb switch
