So I'm planing on building a system like this and i would like some input like should I get the dark rock 4 or the pro one. Is the power supply to overkill or is it good, I might want to overclock in the future so i want to have a good enough power supply and cooler if i do overclock. Also i'm not to sure on the motherboard, i'm trying to build a build that will cover me for the future. Thanks for any input.
This is my system
https://pcpartpicker.com/user/GotEm/saved/32qXP6
https://linustechtips.com/topic/999597-building-a-new-system/
What are you using the computer for? If gaming, please specific the resolution/refresh rate. Also what is your budget
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/999597-building-a-new-system/#findComment-12002885
8 minutes ago, GotEm said:
I'm building this PC for gaming and I the resolution is going to be 1920 by 1080 and the refresh rate maybe 144 or 120. My budget is $3000
Make sure you quote or mention people when replying @GotEm, otherwise we don't get a notification.
This is way overkill for your needs, and I even trimmed the cost down a couple hundred. I wouldn't recommend the 9700K unless it's within about $20 of the 8700K. There's very little difference between them at all.
If you want to save significantly more money, I would go for something like this
This is still super overkill for 1080p gaming, but it saves you a bunch of money and will be a great system for years to come. You can change out pieces like the case if you want something else or something less expensive. You can also add more storage if you want that as well. Bigger SSD if you want. You won't really notice a difference between a 2.5" SSD and an NVMe SSD when you're just gaming, so you might as well save $100.
https://linustechtips.com/topic/999597-building-a-new-system/#findComment-12002950
@Cereal5
Thanks on the first build recommendation I might go with that I'm just trying to build a PC that will last a long time and i don't really want to go with a AMD build. Any idea what the XC means on the 2080. Also i might just replace the 2 TB hard drive with another 1 TB SSD but should i just go with one 2 TB SSD or two 1 Tb SSDs.
https://linustechtips.com/topic/999597-building-a-new-system/#findComment-12003006
