Ethernet port question
Go to solution Solved by Godlygamer23,
You're good.
My server is connected to my router with an Ethernet cable that is something like 120ft long.
Yo,
I Have an Ethernet port in my room that goes to the main router room. Would it be better to move the internet in my room then do router > Ethernet > PC or should I leave the router in the other room and just use the Ethernet port in my room to my pc?
Thanks.
CPU: AMD Ryzen 7 3700X | Mobo: Asrock AB350 Pro4 | Ram: G.Skill Trident Z (2x8GB) DDR4-3200 | Storage: Intel 545s Series 256GB M.2 (SATA) SSD/Western Digital WD Blue 1TB/Samsung 860 EVO 500GB SSD | GPU: Zotac Geforce GTX 1060 6GB AMP! Edition | Case: NZXT S340 Black Case | PSU: Corsair HX750 | Operating System: Windows 11 Pro | Keyboard: Ducky One 2 Mini White MX Brown | Mouse: Logitech G Pro Wireless | Headphones: Astro A50 Gen 2 | Mic: Rode NT-USB | IEMS: KZ ZSN Pro X
https://linustechtips.com/topic/999543-ethernet-port-question/
6 minutes ago, hconverse02 said:
As long as it is just cables and extensions, there's no need to move the router closer with a wired connection
Okay, thanks.
https://linustechtips.com/topic/999543-ethernet-port-question/#findComment-12002525
You're good.
https://linustechtips.com/topic/999543-ethernet-port-question/#findComment-12002536
