So, I own an old acer laptop with a 2nd gen i3 processor. the thing runs very slow but is still usable, the problem is that tobay when i went to start it it booted up to a certain point, then it got stuck on the loading screen i tryed to fix the issue in the recovery menu or whatever it's called. i tryed booting into safe mode, that didn't work so now it's stuck in a boot loop and everything i tryed to do to fix it didn't work. I'm thinking of buying a HDD dock so i can copy the pictures and other things i have on there then deleting everything on the HDD
and reinstalling windows. please help me i need the laptop to work asap bc i'm gonna need it to download more shit for an upcomming pc build, you know, drivers and shit. so if anyone got suggestions let me hear them.
https://linustechtips.com/topic/999260-i-need-help/
Sounds like the HDD might be dying. If you can, try testing it in another system. Use CrystalDiskInfo to see how the drive's doing.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/999260-i-need-help/#findComment-12000632
