I just got a bunch of new parts (graphics card, mobo, CPU and ram), and when I had reassembled my pc and turned it on and got to BOIS, I noticed that 1. My AIO Pump was showing N/A, and 2. The pump wasn't running.
I'm reaching 80c (~175 F) even though I'm just in BIOS, and I have tried to swap around the cables for the pump. The manual says that the two fans on the radiator plugs into CPU_FAN and _OPT, and that the pumps has to be plugged in AIO_PUMP.
I even tried to tilt the case in an attempt to force the collent into the pump in case it was filled with air. I have also tried to reaply the thermal past and made sure it was safely secured.
Specs:
Mobo: Asus Z370-F gaming
Graphics card: Asus 1060 6gb ROG Strix
Ram: G.Skill TridentZ 3200 MHz
CPU: I-5 8600K
Water cooler: Swift Tech H220
https://linustechtips.com/topic/999173-aio-pump-not-working/
  • 4 years later...
