Pls help
long story lets make it short:
today i ran some games and it freeze(sometimes even my pc restarts automatically)
 and i cant even display sign in option when i pressed ctrl+alt+delete
and tried again and task manager says my device is low on memory
how to fix that i have 8gb and it is already enough for some aaa titles games
https://linustechtips.com/topic/998753-ram-problem/
Just now, WhyThereIsAPieOverHead said:
World of warships
PUBG
Fortnite
Minecraft
Universe sanbox
Euro truck simulator 2
and it freezes in all of them?
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997079
1 minute ago, WhyThereIsAPieOverHead said:
World of warships
and Kerbal space program
but strange
no problem for PUBG
and fortnite
ok. did you close all of your other stuff before gaming? 8gb of ram isn't much, so it would be wise to close your web browser among other things before playing ram heavy games.
She/Her
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997092
yes close almost every thing except task manager
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997097
that's weird. how much ram does it use before freezing?
She/Her
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997102
I'm not sure why you're assuming it's a RAM issue, I think all of those games run fine with 8GB, and even if they needed more, they'll just use pagefile unless you've disabled it, in which case the program would just crash. It's more likely to be a CPU, GPU, MOBO e even PSU problem.
CPU: R7 5700X3DMotherboard: ASRock B550M-ITX A/C | Cooling: Deepcool AG400 Digital w/ Corsair ML120 Elite + 1 ML120 Elite exhaust + 2 ML140 Elite intake
RAM: 2x16GB Netac DDR4 3200MT/s | GPU: Gainward RTX 3080 Phoenix (+212MHz / +1000MHz / -6% PL)
Storage: 2TB XPG S70 Blade, Seagate Barracuda 2TB, Samsung 850 Evo 250GB (caching the HD) PSU: MSI MAG A750GL
Monitor: 2x Pichau Cepheus Fuse 28" 4k 144Hz HDR | Keyboard: Corsair K100 optical-mechanical
Headphone/headset: Kuba Disco Pro/Gamer + Beyerdynamic DT-770 Pro | OS: Windows 11 Home
Mouse: Logitech G502X + Ugreen Ergonomic MouseCase: Corsair Carbide 400C
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997110
but Task manager says im low on memory
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997118
I dont know i cant access to task manager after freezing
when i managed to open it says uses 60-70%
that's weird. have you tried running it with one ram stick?
She/Her
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997122
specify please? it never says you're low on ram as far as i know. it just shows how much ram is used.
She/Her
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997125
Are you getting stuttering in the game or full system freeze? As you said it even turns off sometimes, I would assume it's a full system freeze. Low memory available doesn't cause that, only stuttering because of the low speed of the pagefile.
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997132
i only have 1x8 gb ram
i forgot to take a screenshot
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997133
sometimes system freeze with auto reboot
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997142
what motherboard do you have and what slot is the ram in?
She/Her
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997146
no ,how can i oc an non k cpu? XD
XMP has to do with the memory.
i said any OC, so that includes gpu etc.
She/Her
https://linustechtips.com/topic/998753-ram-problem/#findComment-11997183
