The best case that is currently available would be the Corsair 800D. This is mostly a watercooling case though. Though the 900D is just around the corner (May-June) that I would personally wait for.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/9987-best-e-atx-case-with-window/#findComment-108109
NZXT phantom and buy the separate windowed side panel for like $15 and the case is the cheapest E-ATX case you find
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/9987-best-e-atx-case-with-window/#findComment-108111
The only NZXT Phantom
http://www.nzxt.com/new/products/crafted_series/phantom
https://linustechtips.com/topic/9987-best-e-atx-case-with-window/#findComment-108140
fractal R4 or Arc Midi (either version) can take an E-ATX.
just have to re-route the 24-pin and GPU power around mobo.
that's a FD Arc Midi V1 with H100 (push/pull) and self modded
side window. the R4 window panel works as well.
airdeano
https://linustechtips.com/topic/9987-best-e-atx-case-with-window/#findComment-109006
