Hi Everyone!
I have recently been looking into moving away from my headset and going towards a setup with my ATH-M50s.  I had strayed away from them when I was given a headset and needed to use the mic on it.  I plan on picking up a snowball mic to fix that problem.  The next thing I have been looking into is getting a external dac to fix some static issues as well as connect my headphones and speakers all into one box.
I have found this but could not find too heavy of info about it so I was looking for opinions:
http://www.amazon.com/Syba-Stereo-Headphone-Amplifier-SD-DAC63057/dp/B009WN7QT4/ref=sr_1_4?ie=UTF8&qid=1389229990&sr=8-4&keywords=external+dac
And just as a comparison how would this stand against a FiiO e10? (trying to stay at or below the price of 80$)
Thanks for your help
https://linustechtips.com/topic/99775-help-choosing-a-dac/
You can go for something like the ATR2500 or ATR2100 where you can use them as your primary sound device through your headphones, I suppose?
Current PC: AMD FX8320 || PNY GTX 770 || 2x4GB || ASUS M5A97 || Corsair TX 750 V2 || Asus Essence STX || CM Storm Enforcer
Peripherals: Logitech G500S || Cooler Master Quickfire TK || Audio-Technica AT2020 || Focusrite iTrack Solo || Q701 + DT990 Pro
https://linustechtips.com/topic/99775-help-choosing-a-dac/#findComment-1334796
I know that the increase in quality from it may not be very large but it was also to get away from interference I was having from my graphics card.  From what I understood an external dac would solve this issue?
Correct, you'll want to get something that has a digital input via USB or optical.
https://linustechtips.com/topic/99775-help-choosing-a-dac/#findComment-1334814
