It sounds like you stripped the head?  I couldn't see it in the video.  You should Google stripped screw (with Safe Search on) to see what suggestions may help you out.  You may need a new tool to get it out unless you have a tiny hex head available to try on that tiny screw.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/996958-please-fricking-help/#findComment-11982943
5 minutes ago, Jinxc said:
So i was gonna put in my m2 drive and the screws are tight as hell and got rounded like they were jello... Any tips on what to do?
You can try a couple things.  A larger bit on the screwdriver may help.  you may also try needlenose pliers on the stand and take the stand out also, then you can really put force into it without risk to the motherboard.
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
https://linustechtips.com/topic/996958-please-fricking-help/#findComment-11982946
Try these methods:
I personally like the superglue method
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
https://linustechtips.com/topic/996958-please-fricking-help/#findComment-11982947
1 hour ago, Krosis said:
Try these methods:
-ifixit link-
I love ifixit.
Seriously though the rubber band and the superglue work really well.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/996958-please-fricking-help/#findComment-11983350
