OK so i never post to forums so forgive me if ive put this in the wrong feed or mess this up in any way. Moving on;
I have an issue that has put me at a loss for the last couple of days and I just cant figure it out, As the topic states it has to do with an over-current message. I know what this message is and how to trouble shoot it in a basic sense. Problem is, I only get the message when i plug in one of my Gaming mice. I have a Razer Deathadder that I thought broke, and replaced it with a Logitech g502 four days ago. As of 11/16/18 I get an over-current message only when one of these peripherals are connected. If I plug it in after the PC has started up it disrupts the rail and kills my other peripherals. I have a tertiary HP work mouse that works fine regardless though. Oh I forgot to mention that i did troubleshoot and checked my drivers, inside the motherboard for mangled USB connections and the like to no avail. If any of you know in any way i can fix this it'd be much appreciated!
Its a Asus ROG G20CI. Cant figure out which moard it has.
Little did i know... Spray and pray does NOT apply to intimate situations...
https://linustechtips.com/topic/996652-usb-over-current-detected/
