hi guys i am new to pc building so need some questions answered. so i have already put a post up on what parts to get and i think they are compatible. if have read alot of complaints about the motherboard im buying asus strix b350-f about how little ram it supports i have picked to get some vengeance lpx 3000mhz 8gb ddr4 c15 xmp this is on the motherboa rd qvl but i wanted to ask for security reasons if this will work for definite. one of the other things i dont understand is about the gpu drivers and if this gpu will work with the motherboard i have picked the gigabyte radeon rx 580 gaming will the motherboard and gpu work together, also about the gpu when i went to look at the drivers on the gigabyte website i saw 3 bios drivers and 2 utility drivers and ovs the regular driver what are the bios updates and should instal them and do i need them?
https://linustechtips.com/topic/996386-gpu-and-components-compatibilitydriversbios/
woah sir this was a jumble of words and punctuation. That aside, the the ram and rx580 will work with the motherboard you have picked. Though, if you haven't bought the motherboard yet I would suggest a B450 board over a B350 motherboard. Also Asus has a tendency to overprice their stuff especially when its "gaming" or "strix" stuff. I have a strong feeling you're not going to overclock the ryzen cpu you have picked out though
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
I know I wrote this at 4.00 in the morning from where I come from. anyway why would a b450 be better than a b350 ? I will oc  the CPU but not by much just a little bit more performance out of the processor for streaming and editing. Do you know anything about the gpu drivers I asked about I'm very confused about all of that?
was the bios drivers called updates? also can you link me the site that can help
8086k
aorus pro z390
evga 3070 ultra
Here is the drivers page https://www.gigabyte.com/Graphics-Card/GV-RX580GAMING-8GD-rev-10-11#support-dl
The drivers are named F82, fy1,f91 very confused with this
Sorry didn't read your question currently no they are advertised as downloads not updates. Contacted the manufacture and they didn't help with understanding what to do.
They're the display drivers. You install them so you can see what the graphics card is displaying to the monitor
8086k
aorus pro z390
evga 3070 ultra
Thanks I got a message from the support team and they said I can also go to the AMD website and download the drivers from there is there any difference from AMD website or gigabyte. Don't know why there is 2 website with different drivers? Here is the AMD link
https://www.amd.com/en/support/graphics/radeon-500-series/radeon-rx-500-series/radeon-rx-580
I believe theres different drivers because AMD sells their own RX 580's, so you would install the drivers from AMD if you buy a card from AMD thats made directly by them. If you buy the GIGABYTE card then install their drivers that they provide. I think they actually might be the same but to be safe just get the gigabyte ones.
8086k
aorus pro z390
evga 3070 ultra
ahhh that makes sense thanks allot for the assistance. i will probably be on this next for help with something in the pc. getting the ports tomorrow thanks again all the best.
good luck!
8086k
aorus pro z390
evga 3070 ultra
