I need help
Go to solution Solved by Leedog,
I setup a pin not a password but it’s asking for a password if anyone knows how to reboot from ASUS BIOS or how to access windows BIOS please lmk I need to get work done ASAP
1 minute ago, Leedog said:
So I recently put my computer into safe mode and I can’t get it out I’m locked out of my computer and login is different i guess and I just need help
What version of Windows are you using and did you go into safe mode on purpose to try to get into your computer because you got locked out of it or did it somehow boot into safe mode automatically when starting the system?
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/996173-i-need-help/#findComment-11976601
Is it asking for a different type of password? You should be able to change what type of password it asks for, I did that once and I got scared, it was asking for my longer password, but I changed it back to the PIN.
Main And Only Build : CPU : Ryzen 5 1600x (OC to 4.2GHz), Cooler : Thermaltake Floe Riing RGB 240 TT Premium Edition, Motherboard : Asus ROG Strix B450-F Gaming, RAM : Trident Z RGB 16GB (2*8) 3000Mhz DDR4, GPU : Gigabyte Gaming GTX 1070 TI, PSU : EVGA G3 650W 80+ Gold Certified, Storage : 250GB Samsung 860 Evo + 256GB SU800 + 2TB Seagate HDD.
https://linustechtips.com/topic/996173-i-need-help/#findComment-11976648
