I have an Aspire R3 Series laptop that's missing a place to plug in a SATA cord,  and I couldn't figure out what to search for online (to possibly try and solder a port back on)  so i was wondering if anyone could help me find one or give me a different solution to connect a hard drive without plugging one in via USB.
https://linustechtips.com/topic/996121-hard-drive-port-help/
I dont think there's even a solder point for SATA devices.
Desktop benching:
https://linustechtips.com/topic/996121-hard-drive-port-help/#findComment-11976237
The motherboard has to support it with the SATA controller so if it's not there it's probably not supported
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/996121-hard-drive-port-help/#findComment-11976258
I was looking into it and someone elses laptop that was the same model had one so i'd think mine is compatible,  unless mine was different in some way.
https://linustechtips.com/topic/996121-hard-drive-port-help/#findComment-11976266
