RYZEN 5 1600X AM4 3.6G 16MB 95W 2400MHZ
ORSAIR - Vengeance LPX 8GB 2.4GHz PC4-19200 DDR4 DIMM Unbuffered Non-ECC Desktop Memory - Black
WD - Blue 1TB Internal SATA Hard Drive for Desktops (OEM/Bare Drive)
Corsair - Carbide Series ATX Mid- Tower Case - Black/Red
MSI MB B450 TOMAHAWK AMD AM4
EVGA - NVIDIA GeForce GTX 1060 SSC Gaming 6GB GDDR5 PCI Express 3.0 Graphics Card - Black
EVGA - 500 Bronze 500W Power Supply - Black
Will I be able to build a PC with these stuff? Yes I will also be getting windows 10 through a USB.
https://linustechtips.com/topic/995757-build-for-now/
Well, yeah, those are pc components after all.
Why is the r5 1600x listed as 2400Mhz tho lmao
I suggest getting the cheaper 1600 instead of the 1600x, cheaper faster RAM, and an SSD.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/995757-build-for-now/#findComment-11973722
Get an RX 570/580/590 if it's way cheaper/same price/nearly same price.
the 580 will save you money on a future free-sync display.
Otherwise try to get 3000mhz memory
THe 1600X doesn't come with a stock cooler, should just get the 1600 instead if it's cheaper, or a 2600 if the price is close.
https://linustechtips.com/topic/995757-build-for-now/#findComment-11973732
it'll work, but get a ryzen 2600 instead of the 1600x and a corsair CX450/M or coolermaster masterwatt instead.
https://linustechtips.com/topic/995757-build-for-now/#findComment-11973784
13 minutes ago, Gldendeath said:
Ok, so far im going to switch to the AMD Ryzen 5 2600, I'lll also get the corsair CX450/M, and I plan to stick with the gtx 1060 until i change i mind. Thanks for the help. ❤️
What's your country?
https://linustechtips.com/topic/995757-build-for-now/#findComment-11973819
59 minutes ago, Gldendeath said:
I live in NA
As in north america because that isn't a country...
It's most likely that an RX 570/580 is cheaper and has close to/same performance as a 1060.
https://linustechtips.com/topic/995757-build-for-now/#findComment-11973933
