Hi,
was unsure where i should post this really but any way so i have a 2 pc setup currently which consists of 2 pcs, 2 consoles that are plugged in and a htc vive. So first really what is the best way to connect this all to achieve no issues with hardware as currently my 21:9 monitor will only show 1080p and not the correct resolution as im having to use the display port to hdmi for my lg monitor as the vive takes the HDMI port.
So what i have basics, I5 8600k just brought 16gb DDR4 ram 1060GTX 3gb WF OC gaming rig and the stream rig AMD 6100 FX to be swapped soon to my i5 7500 i have, 12gb DDR3 ram 760GTX; 1 HDMI 2x output and 1x input splitter, 5 input and 1 out put HDMI switch. Also have a behringer 8 input mixer.
Tried couple things but let me know what i can do thanks :D
Gaming rig: Windows 10 Home 64bit Gigabyte z370 hd3p Intel I5 8600k 16Gb Corsair Vengeance DDR4 240gb SSD & 1tb HDD Sound Blaster z, 2070 RTX windforce, Cooler Master Cosmos Case
Stream rig: Windows 10 Home 64bit, Gigabyte GA-970A-DS3, Amd FX 6100, 12gb mix ddr3 ram, 1060 3gb gtx windforce oc, avermedia c985, 120gb ssd, 500gb HDD,
https://linustechtips.com/topic/995649-stream-setup-with-vr-help/
Bump
