Help with sli bridge
Go to solution Solved by RollinLower,
1 hour ago, bebejapes said:
i wanted to get zotacs but it saying 0 slot and i have no idea what that does for me
0 slot means the bridge is spaced for 0 slots between the GPU's. You need the 2 slot version.
https://www.google.nl/search?q=zotac+2+slot+hb&oq=zotac+2+slot+hb&aqs=chrome..69i57j0l2.4398j0j7&client=ms-android-essential&sourceid=chrome-mobile&ie=UTF-8
1 minute ago, RollinLower said:
depends on the spacing between the cards. i would recommend a HB bridge tough.
im not sure as to how to describe the spacing.
its on my x470 fatality asrock board. and the gpus are both zotac 1070ti and its on a full tower case.
https://linustechtips.com/topic/994213-help-with-sli-bridge/#findComment-11959793
that board has 2 PCIe slots between the large 16X slots for your GPU's. so you'd need a connector with 2 slot spacing.
any HB bridge will do, just get the one you think looks best.
https://linustechtips.com/topic/994213-help-with-sli-bridge/#findComment-11959798
https://linustechtips.com/topic/994213-help-with-sli-bridge/#findComment-11959805
https://linustechtips.com/topic/994213-help-with-sli-bridge/#findComment-11959961
