So i just gotten my ryzen build finished and been using it for a while , everyhing is fine , just one problem. So everytime i press the power button for my pc , everything turns on and it goes well but there is no signal. After 3 seconds and turns off and on again , and boots to windows. I dont know whats going on and i havent overclocked the cpu , while the gpu is factory overclocked. Also , there was one time when my pc didnt give any signal mid game and all the fans went to max rpm and the water pump of my system going full power and the power button not turning the pc off so i had to turn off the power supply and turn it on again to make it work. Does anyone have any explainations?
Specs:
Ryzen 7 2700x
Asus ROG Strix X470-F Gaming
Zotac RTX 2080 AMP!
16GB 3000MHZ Trident Z RGB Ram
CoolerMaster V750 80+ Gold
CoolerMaster MasterLiquid 240 L RGB
250GB SSD Boot Drive
NZXT S340 Elite
                                    Desktop
R7 2700xRTX2080 AMP! 8GB Asus ROG Strix X470-F Gaming CoolerMaster ML240L RGB | CoolerMaster V750W 80+ Gold | NZXT S340 Elite White | Toshiba P300 7200 RPM 1TB HDD | Samsung 860 EVO SATA
PCPP Link https://pcpartpicker.com/list/8QyrLJ
                      Laptop(Acer Nitro 5 2015)
I7 6700HQ | GTX 950 | 8GB DDR4 1TB OEM HDD | 250GB OEM M.2 SSD
https://linustechtips.com/topic/993773-help-booting-issue/
bios is updated , ram is F4-3000C16D-16GTZR
                                    Desktop
https://linustechtips.com/topic/993773-help-booting-issue/#findComment-11956321
