Hi!
So I just moved and got a new work desk and now my PC (which is currently in a CM Master Box 5) won't allow me to fit two monitors on the desk, when I try to move it elsewhere I encounter a problem, it doesnt fit, the case is just a bit too long. So I am looking for a replacement.
I am lookig for a case that is smaller than 250mmx490mm (height is not a problem), supports ATX PSU and ATX MoBo.
It also has to have good air flow since I have a Vega 64 inside (310mm long).
It should be cheaper than 70€/90$.
Thank you all for your help :D
https://linustechtips.com/topic/993699-need-help-with-new-case/
54 minutes ago, LukeSavenije said:
I checked the manufacturer's website and it states that the case is 492mm long, I need it to be shorter than 490mm even better shorter than 480mm. Still thank you for the suggestion ?
https://linustechtips.com/topic/993699-need-help-with-new-case/#findComment-11955034
