Hey Guys, I would like to know if you would have suggestions to get the most Silent Build Possible in an Open case(cougar conquer to be more Specific)
I would like to see what you would use as CPU and GPU and Also Cooling Solutions to get the most powerfull Silent Open case Build
Intended use for the PC:
-Gaming, Streaming and Recording(at the same time) AAA Games
-Video Editing and Rendering With Photoshop and Premiere Pro
Minimum Specs:
-CPU running at Minimum 3GHz with at least 10Core/20Thread(or 20Core/20Thread)
-GPU 980ti or better
-at least 4TB for RAW Storage, 1TB SSD(SATA or M.2) for Fast Storage and 500Go M.2 SSD for Windows
-32GB of RAM
-Need to be able to connect to at least 4 Monitors
Bonus Point if you can come With a build that looks Great
https://linustechtips.com/topic/993344-open-case-silent-pc-build/
16 hours ago, James Evens said:
NSG S0
Good luck to find one for sale.
No i don't want to change case, I have the Cougar conquer case, i was more wondering about the Hardware poeple would use for a super quiet system while still having lots of power and also not giving up on a case because it lets too much sound out, i choose the conquer case because i like the challenge, every thing from cable management to LED Strip layout is just so difficult since it's just open every where :)
Go full watercooling if you have the cash. Your biggest enemy is going to be heat especially under load which will create noise. A custom loop would give you the best chance especially if going with a 10 core cpu or above. You can fit a 360mm and 240mm rad in that case according to the specs on Cougar website.
Jayztwocents did a Threadripper custom loop build in it:
