Okay, so i don't really know what it is that I'm doing with this kind of stuff, which is why i am now here asking you guys about how to fix this.
Basically, the issue that i am having is that the temperatures on each of the CPU cores are way too high ( talking like idling i'm at 54-58 C on the cores, and under load the system is basically being pinned at 100, which definitely isn't good), my system specs are as follows:
 ASus maximus gene 8
32gb DDR4 hyperx ram
gtx 1070 evga FTW
i7-6700k ( it is at stock, with a base speed of 4 GHz, however it seems to be pinned at 4.2GHz, even when not under load, and from looking at CPUZ, is at 1.375v, which i don't think the voltage on the cpu should be that high considering the situation)
finally the cooler i am using is the enermax liqmax 2 240s liquid cooler AIO.
This has been an issue for a while now that has been very irritating, but i just haven't had the time to do anything about it till now.
If it helps, i have not overclocked the system since i built it a few years ago, but as such, don't really know how to navigate the system bios that well.
I don't really know what to do about this, so if anyone has any ideas on what to do to fix it, that would be much appreciated.
I really just want to make it so that the computer isn't quite as loud as it currently is, and i want to make it run significantly cooler, since i am worried about the life span/ condition of the CPU from it running this hot for a long period of time.
The only thing that i could really think of is maybe to get a new cooler, since this one is like 3 years old at this point, but it is a good cooler and is still an liquid cooler, so surely it should be fine, and i have already tried reapplying the thermal compound to the CPU, but that did not seem to do anything really to the temps, so i don't this that was or still is the issue with it.
Anyway any help with  the issue is much appreciated,
Thanks.
https://linustechtips.com/topic/993205-cpu-overheating/
Based on those temps, it seems 1 of 3 things.
A) Pump is dead - Does the pump output any type of vibrations, RPM readings in software, etc?
B) Bad mounting of the cooler - likely not the case since you have reapplied paste previously.
C) Cooler not plugged in properly and not producing enough flow as a result.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/993205-cpu-overheating/#findComment-11950355
i dont think that the pump is dead, i know that the enermax pump is supposed to be very quiet for as pump, but from feeling the tubing and the block, i can feel some vibrations, which makes me feel that is is actually okay, though the flow rate thing might be a problem, since i would have thought it would ramp up when the CPU got to that high a temperature and high a load the system would detect it and ramp the fan speeds up, including the pump speed.
But i did just plug it into the CPU fan header, which is what i think was recommended that i do with the AIO (though i can't quite remember fully) so i don't think the issue is that it isn't plugged in properly.
is the voltages and the clock speed of the CPU not an issue? like i dont think it should be running at those speeds and those voltages on idle.
https://linustechtips.com/topic/993205-cpu-overheating/#findComment-11950372
Go to the bios and change the voltage from "auto" to 1.2V and see if that helps at all.
I only see your reply if you @ me.
https://linustechtips.com/topic/993205-cpu-overheating/#findComment-11950390
