CPU temp rises, frames drop, (not a heavy load)
Hey everyone, so I'll make this short and sweet. When I am playing one of my usual MMO's I have had a sudden frames drop. The game is an older one so it caps at around 60 frames or so, but I've noticed at around 5 hours of continuous game time (I work a lot so I deserve this relaxing time :D) and watching movies that my CPU temp will suddenly spike up and my memory usage becomes high and then my frames drop from a constant 60 to a near 30!
So in short: After 5 hours of game time, temps spike, frames drop, high memory usage. I have two clients of the game running at the same time, and Netflix or Chrome open.
I am needing some serious help, my PC should be running flawlessly. The problem is solved by a simple restart. My temps drop back down to the low 30's and everything is heavenly again.
My CPU temp spikes from around 32C to 50C, which is still nothing to worry about, but it's still a spike that happens along with the frame drop and high memory usage.
Ambient room temps on average - 69-72F (20-22C)
PC Specs:
i7 8700k OC'd to 5Ghz @ 1.32V
1080ti SC2
16gb's Corsair 3000Mhz
Corsair h115i Pro
EVGA Z370 board
EVGA G2 550W
Thanks everyone.
https://linustechtips.com/topic/991383-cpu-temp-rises-frames-drop-not-a-heavy-load/
PC Specs:
1080ti SC2
Corsair h115i Pro
EVGA Z370 board
EVGA G2 550W
Thanks everyone.
Turn off vsync.
Vsync operates in steps.  Depending on the monitor.  Typically 0 - 15 - 30 - 45 - and 60. so if your PC cant output 60 or more FPS.  then vsync drops to a lower step.  so if for an instant your PC can only render 55FPS.  Then you drop for a second to a 45FPS cap and then back to 60 again a second later.
If your display only support 30hz or 60hz then the 45hz step is eliminates.  so if you PC can only do 55FPS, then its going to cut everything and run at 30, until your PC can do 60+ FPS again.
Linux Daily Driver:
CPU: R5 2400G
Motherboard: MSI B350M Mortar
RAM: 32GB Corsair Vengeance LPX DDR4
HDD: 1TB POS HDD from an old Dell
SSD: 256GB WD Black NVMe M.2
Case: Phanteks Mini XL DS
PSU: 1200W Corsair HX1200
Gaming Rig:
CPU: i7 6700K @ 4.4GHz
Motherboard: Gigabyte Z270-N Wi-Fi ITX
RAM: 16GB Corsair Vengeance LPX DDR4
GPU: Asus Turbo GTX 1070 @ 2GHz
HDD: 3TB Toshiba something or other
SSD: 512GB WD Black NVMe M.2
Case: Shared with Daily - Phanteks Mini XL DS
PSU: Shared with Daily - 1200W Corsair HX1200
Server
CPU: Ryzen7 1700
Motherboard: MSI X370 SLI Plus
RAM: 8GB Corsair Vengeance LPX DDR4
GPU: Nvidia GT 710
HDD: 1X 10TB Seagate ironwolf NAS Drive.  4X 3TB WD Red NAS Drive.
SSD: Adata 128GB
Case: NZXT Source 210 (white)
PSU: EVGA 650 G2 80Plus Gold
1 minute ago, MedievalMatt said:
Turn off vsync.
Vsync operates in steps.  Depending on the monitor.  Typically 0 - 15 - 30 - 45 - and 60. so if your PC can output 60 or more FPR.  then vsync drops to a lower step.  so if for an instant your PC can only render 55FPS.  Then you drop for a second to a 45FPS cap and then back to 60 again a second later.
I'll have to try this later and come back with an answer to you, but I'm still curious as to why my PC would suddenly not be able to run the MMO?
I have noticed it going on for 2 weeks all of a sudden. I don't have anything malicious, I've checked.
I'm stumped as to why a rig as strong as mine would drop in performance when under load on an old game at around the 5 hour mark EVERY time?
Could be a number of factors.  When i used to play WoW there was one zone i would go to and get shit like 20 FPS.  then another zone over be over 75FPS.  it all depends on how optimized the game is, there could be a memory leak somewhere, or the 2 clients start having issues with addressable VRAM.  Hard to say exactly.
Linux Daily Driver:
CPU: R5 2400G
Gaming Rig:
Server
CPU: Ryzen7 1700
GPU: Nvidia GT 710
SSD: Adata 128GB
I agree with corrado33. A few years ago I had a similar problem where a virus would crash my computer by taking up all of my CPU and RAM usage. I only found out later by looking at task manager. Although unlikely, it could be helpful to see if a specific program is eating up your ram and cpu.
