CPU: intel 15 3570k
MB: AS Rock z77 extreme 6
RAM: 12 gb corsair vengence
GPU: 2x nvidia geforce gts 250 (sli)
PSU: 550 watt
HDD: 500 gb seagte black
COOLING: corsair h100 liquid cooler
FANS: cooler master green led 120mm sickle flow
CASE: cooler master haf xb "lan box"
https://linustechtips.com/topic/9910-project-biohazard/
Ah :| ...ok. Did you wanna talk about it?
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/9910-project-biohazard/#findComment-107340
Why do you want two GTS 250s? You can't power them anyway. I would get a 660ti for the money that you would buy the 250s for.
https://linustechtips.com/topic/9910-project-biohazard/#findComment-107345
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/9910-project-biohazard/#findComment-107381
just drop the 2 GTS250 those are old and slow cards. get a newer and better single card from AMD that fits your budget specially HD7770 and even the new 7790 looks like a good value. and from all the testings done it looks like AMD cards are kicking GTX butt.
how is it that you are running 12GB ram? is it a triple channel memory for older LGA1366? if so just change it a dual channel kit so you can avoid miss matched RAM not letting the PC boot or RAM not running at the max possible settings.
https://linustechtips.com/topic/9910-project-biohazard/#findComment-109169
