Yes and yes, unless your motherboard is like 15 years old
H500 supports 240 and 280 mm rads and per the spec sheet of the cooler:
Quote
Cooling socket support intel 115x, intel 2011/2066, amd am3/am2, amd am4, amd tr4. Note-intel lga 2011 and lga 2066 does not require backplate installation. Radiator dimensions is 10.87 x 4.72 x 1.06 in inches
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/990941-will-it-fit/#findComment-11929263
