Problems coming from graphics card?
Solved by kristaps552,
When I try to do the command, it says only administrator can do it, which is odd because I'm the only account on this pc and I am administrator.
I am a bit noob on this. Whats a system restore?
Run CMD as an administrator. Right click on cmd and run as admin.
If you don't know what it is, then you probably haven't done it. What system restore does is, it Restores the system to the previous state, before any major change in the system file etc. has been made. e.g. drivers. You could try that and do a system restore from when everything was working ok, and possibly see what caused it.
