I have an i7 6700K with ASUS multicore enhancement enabled and what that does is it makes the cpu turbo boost to 4.2ghz on all cores but when I was looking at CPU z during cinebench I noticed the voltage was at 1.344 sometimes up to 1.368 any idea why and how to fix it? I know some of you will say disable multicore enhancement but I like to be turbo boosted on all cores. I have a Z170-A and a kraken x52 cooler btw during games my cpu reaches 64C
https://linustechtips.com/topic/989866-problem-with-my-cpu-voltage/
Just now, Randomizer23 said:
Are you sure because I don't want any cpu degradation. And can you recommend a good voltage for a 4.5ghz OC on my chip thanks
I dont have data on that overclock as overclock is literally just trial and error.
Anything up 1,4 volts is fine. Anything above and you start get i to degredation territory.
Ok thank you
