I recently built my computer and about every 30 or so minutes after I start it up the computer either freezes or gives me an error that says "CLOCK_WATCHDOG_TIMEOIT". I've Googled how to fix it and none of the options are working. All my drivers are up to date and everything like that. I've also did a fresh install of Windows but the problem is still happening. Is there a way to fix it?
https://linustechtips.com/topic/989840-how-do-i-fix-error-clock_watchdog_timeout/
CPU: Instability with frequency or voltage or both. Reduce frequency and/or increase voltage.
Also possibly related to RAM
Desktop benching:
Do you have any components to try swapping in? Anything, be it a GPU, motherboard, CPU or even power supply? Also, re-seat everything.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
CPU is on default settings and I have nothing to swap out.
Try clearing CMOS.
REMEMBER:
OR
CPU - Ryzen 5 2400G
PSU - EVGA 450BT
then try drop the memory frequency as low as possible
Desktop benching:
