So I have a old 2011 1080p 60hz monitor and i want to upgrade it to a 1080p 144hz monitor but if i get a new monitor then my graphics card, an overclocked rx 550, wont be able to take advantage of the 144hz. But if i get a new graphics card then the extra preformance will be wasted. Please help I only have enough money to buy 1 upgrade. thx
https://linustechtips.com/topic/989496-help-which-upgade-do-i-get/
no it won't, just turn up the quality settings.
Desktop benching:
Get a new GPU first.
If your current GPU can't run a monitor to its potential, then upgrading the display now would be a bit of a waste of money.
RX 580 is good for high details 1080p. Since you have a budget 550, you must also have a low end CPU too. Are you sure that can keep up with 144Hz?
Primary PC:
PSU tier list
How many watts do I need?
