hi everyone.
I was busy installing mint on a usb stick (i have reasons for it) and my system crashed. now mint installer and windows 10 can't access or format the stick. I already tried the clean command, but that wouldn't work, checkdisk doesn't work either. what else could I do?
Thanks in advance
https://linustechtips.com/topic/989427-usb-not-formatting/
it just says that it can't complete the format, so i'm out of luck or could I try anything?
2 minutes ago, Electronics Wizardy said:
probably a dead usb stick. They normally go read only on a error, so just get a new one.
https://linustechtips.com/topic/989427-usb-not-formatting/#findComment-11915880
Unless there is a read only switch on the usb, there really isn't anything to do. The usb sticks are basically designed to be disposable.
https://linustechtips.com/topic/989427-usb-not-formatting/#findComment-11916125
yeah, with a sandisk stick from the local action that isn't going to happen. too bad then
https://linustechtips.com/topic/989427-usb-not-formatting/#findComment-11916128
