I need to get a cooler for my 1600x that can fit into the coolermaster masterbox lite 5. https://www.ebuyer.com/827265-coolermaster-masterbox-lite-5-rgb-gaming-case-mcw-l5s3-kgnn-02 I don't plan on over clocking and really the cheaper the better.
My motherboard is https://www.ebuyer.com/789970-msi-amd-ryzen-am4-b350-gaming-plus-atx-motherboard-b350-gaming-plus not really sure if that makes a difference but just in case.
https://linustechtips.com/topic/989326-cpu-cooler/
If you aren't overclocking then why not just use the stock cooler that comes with it? The stock coolers for Ryzen products are actually pretty good and can even handle mild overclocks.
https://linustechtips.com/topic/989326-cpu-cooler/#findComment-11914809
