8 minutes ago, BrokenProgram01 said:
two things can be happening here either your overclock could be unstable or your GPU could be downclocking due to there being no load on the GPU
usually, if you have a bad overclock it will get stuck at the lowest frequency
https://linustechtips.com/topic/989185-overclocking-issues/#findComment-11913549
So after it does that, going back into a game, it will stay at 400?
https://linustechtips.com/topic/989185-overclocking-issues/#findComment-11914659
yeah it will stay at that clock speed until i restart my pc. even restarting afterburner doesnt fix it. Its not afterburner either because cam does the same thing. I lowered my clock speed now im hoping it fixes it.
https://linustechtips.com/topic/989185-overclocking-issues/#findComment-11916118
