Cpu cooler
Go to solution Solved by WoodenMarker,
15 minutes ago, DuckyChanQuack said:
would it happen to also still fit if I had slots 1 and 3 populated with ram ? also sorry about the double post I am very new to this forum stuff
Yes, it would fit. Here's an example with the B350M Mortar Arctic which has the same layout: https://pcpartpicker.com/b/mmLJ7P
You can see that the first slot is unobstructed.
208511.f0ce7c669185aecee3679d9dad5e4f8e.
FYI, you can edit in tags in the future if you forgot to do so.
Yes it fits. The only time the stock cooler wouldn't fit due to ram is if a motherboard violates the exclusion zone around the socket that AMD has dictated.
Moved to Air Cooling.
https://linustechtips.com/topic/988983-cpu-cooler/#findComment-11911313
https://linustechtips.com/topic/988983-cpu-cooler/#findComment-11911319
https://linustechtips.com/topic/988983-cpu-cooler/#findComment-11911401
