Hi mate,
We need more information.
Where is the RGB coming from? (e.g mobo, gpu, ram)
"PC's RGB" is a broad term.
EDIT: If the RGB lights are coming from the fans, there are a few options:
1) There is an RGB controller in your PC case somewhere, generally on the side where all the wires go
2) it is software controller, google the manufacturer and download their RGB software
3) You can't edit the RGB settings and you are stuck with it.
https://linustechtips.com/topic/988907-rgb-problem/#findComment-11912430
