Hi, my pc config
Antec true power 750w
MSI GTX 570
Asus sabertooth x58
Intel i7 950 stock
16GB DDR3 ram
so it has been 7 years since this configuration is running without any problems. Recently, strange thing happend. When i open any game and after random minutes in game, screen gets blacked out and i have to hard reset the machine.
GPU temps are well under limit. Some times it crashes within few seconds of same game, other times its runs for 5 min or so.
GPU has 2x6 pin connectors, and it was hooked to default(2x6+2) PCI-E cables on the PSU. Now when i switched power cables to GPU from default to modular ones (2x6), the macine is stable without any problems.
The default cables and modular cables on psu both are hooked to common 12V3 and 12v4 rails. I dont understand how changing the cables effects this.
~ i7 950 stock | Cooler Master Hyper 212+ | Asus Sabertooth | MSI GTX 570 stock | Antec 750W True Power | Corsair XMS3 4GBx4 1600 | WD Green 1 TB | WD Blue 3 TB  | Seagate Ironwolf 4 TB | Xbox 360 wired Controller | CM Storm ENFORCER ~
~  RIP - Dell Studio 1555 | Backlit Keyboard | 1080 P | Battery almost Dead..  ~
~ RIP - Intel P4 1.7 ghz | 4o GB HDD | 17'' | 256 MB Ram | 845 GLLY | Custom modded led Keyboard ~
~(+ my d3ad brain lol:))~
https://linustechtips.com/topic/988797-antec-psu-using-default-cables-crashes-gpu/
43 minutes ago, emosun said:
are you 100% sure it's the same rail becuase it sure sounds like one rail is going out
i checked this review - https://www.kitguru.net/components/power-supplies/zardon/antec-truepower-750w-new-series-review/2/
Connector
Antec TruePower TP-750
ATX Connector (540mm)
24 pin
12VI
5.25″ Drive (540mm+150mm+150mm)
3
3.5″ Drive connectors (+150mm)
1
SATA (540mm+150mm+150mm)
3
8 Pin EPS12V (540mm)
1
12V2
4 pin ATX12V (540mm)
1
6+2 pin PCIe (570mm)
2
12V3/12V4
Modular Cables
5.25″ Drive (560mm+150mm+150mm) 6
12V1
SATA (550mm+150mm+150mm) 6
6 pin PCIe (560mm) 2
12V3/V4
1 hour ago, emosun said:
well if its the same rail and one set of cables work while another do not then theres a physical problem with the cable or connector or area where they are soldered to the pcb in the psu
thanks, shall i check the voltage in these cables or something else ? i suppose if there was no correct voltage the GPU would not start in the first place.
